On 12/11/2017 at 11:02 PM, wheee! said:
Could’ve been a “brake-in”....
Now it's a breakdown.  A real heartbreaker you're gonna have to crawl under there. :)
Did I do okay?  Sorta corny...
Edited by siteunseen
Wired up my carbon fibre heat lamp today. Now I can powder coat large items.
The lamp head moves up and down the pole. I will hang large objects in front of the lamp and then move the lamp around the object to cure the powder.
Close up of the carbon fibre elements.
Also started work on the HEI ignition upgrade for the GM 4 pin module
Opened the case, drilled out the new aluminum heat sink, and stripped and painted the case to get rid of the little bit of rust on the mounting tabs.
  • Who's Online   0 Members, 0 Anonymous, 1,556 Guests (See full list)
