Finished routing the AC lines and used the quikclip kit to attach all the fittings.
10 from the evaporator to the pump, 8 to the top of the condenser, 6 from the condenser to the drier, 6 from the dryer to the evaporator.
So here’s something cool. I have a couple sets of the rear tail light finishers and none are great. I tested a small broken piece by first media blasting it gently, then spraying it with Duplicolor Graphite wheel paint and right beside that, some commercial chrome spray paint. I think I can live with this until I can afford re-chromed bezels....!
Edited by wheee!
Some more progress on various fronts. I have installed the refurbished factory fan clutch and fan in the car for now. I had a Ford Taurus fan from a JY but there is no way that will for between the rad and L series engine. I like the look of the factory fan in there anyways... This allowed me to install the silicone rad hoses as well. I also installed the cold air intake pipe and hose routing this was key as I had to ensure that the AC lines and the hood hinges cleared properly. Keeping with the front end theme, I spent about three hours cleaning and refurbing the front indicator housings and wires. They had been liberally coated in undercoating somehow by the PO. I will leave the lens polishing for later. The surrounds for the indicators were also somewhat chipped so I tried to use some epoxy to build up damaged areas. I will see if it held well enough to sand and paint today. I installed the centre valance to ensure it cleared the horn mounts and fit along with @EuroDat  's 240 bumper conversion kit. Of course it did! I routed my secret hood release cable into position and found a nice spot to access it in case of power loss. I started disassembling and cleaning up the taillight surrounds. While all this was going on I received a package with exhaust hangers that I will weld into place (on the pipe) to secure the exhaust pipe to the factory mounts.
  • Thanks 1
  • Who's Online   1 Member, 1 Anonymous, 1,402 Guests (See full list)
