I’m not color blind and get color tested every 6 months for work, this is a tough one. Using the process of elimination. The far right must be yellow. The second from left has to be red. This leaves brown and orange. With that I would say far left is brown making the final one orange even though it doesn’t look it. It looks a slightly golden yellow color. Colors can be weird when you put them next to each other. It’s always best to look at them with a totally white background individually. You will probably pick up the undertones you need if you do that vs setting them side-by-side.
Might need to test the wires. Try the white background, you might have luck. Post pics with white background and we can help.
Most of the Haltech is now wired up. I also managed to find a home for the Leopard 2 tank breather filter! Nestled nicely on the catch can!... I tapped the inside of the aluminum filter and threaded the nozzle to allow it to screw on and off!
9ab88a7a998da15eb56e4a1a16378ad6.jpg&key=415d66d7c3e9b42d5baa75c9118bc5c983f6ec3375e457e3e4c2b20b6cfd39b1
Coolness! You've reached the point where the tools necessary for working on your motor are more like an electronics tech than an engine mechanic!  :geek:
What's in the little tub? Flux? That's not the acid based plumbing stuff, right?
Well,  I am making good progress on the wiring of the harnesses and the installation of the new components like the PWM lighting controller for the led dash lights, the push button ignition and RFID remotes, power steering system and the Vintage Air climate control system. Looks like pandemonium I know...
Well the dash is in. Not fully connected yet, but in. Installing the dash with all the connections is tricky, especially with the new hoses for the Vintage Air. Very tight and all in all it took me about three hours by myself. About 50 install/removals included...
Edited by wheee!
  • Who's Online   3 Members, 0 Anonymous, 1,417 Guests (See full list)
