My quotes are all around $8000 for my garage. [emoji21]
Well, how many sqft is your garage. Mine is 1,200 sqft and it was $4500. after t a 10% discount for being retired military. Is that Canadian $$ you’re quoted.
Finally received my digital to analogue tachometer converter. The Haltech sends a digital signal that needs to be converted into the old school coil signal for the tach to work properly.
Pretty simple solution using one of these converters made by Gene. He’s on eBay and sells cool little gadgets like this for a reasonable price.
https://www.ebay.ca/itm/142171581596
Edited by wheee!
  • Like 4
Hmmm. I had turn signals and flashers working before. All the wiring is good. Good grounds. Indicator lights in dash come on solid but don’t blink.
I swapped all the bulbs to leds and added electronic flasher units but now the flashing has stopped working from either the turn signals or the emergency switch. Any brilliant thoughts I should look into first?
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
