I've done a search and can't find anything so this must be a dumb question.
Anyway, My battery was just stiiting in tray without a proper hold down. I've looked at pictues and figure it will be easy to fabricate a bracket.
My question is where does the J-bolt hook to? I see the firewall attachment point but don't see anywhere on the battery shelf designed for the J-bolt. Was it meant to just hook to the lip of the shelf?  Seems mickey mouse to me. I guess I could weld a bracket to the shelf with some holes to hook to.
Thanks,
Steve
Edited by sdyck
https://www.classiczcars.com/topic/51009-battery-hold-down-question/
It just hooks under the protruding lip forward of the battery tray. Since my battery is shorter than the original, I added a painted one inch board under the battery to bring it up to the height of the firewall attachment point for the top hold down frame.
Dennis
Edited by psdenno
My J bolt hooks into one of the bottom front facing holes in the base like Dennis says. The top of the battery's bracket, opposite of the J bolt, screws into the firewall. All nice and tight. The only thing than I worry about is the draining tube comes loose from the bottom tray. I've used zip-ties before but this time I'll use to twisted wire. I'm scared it has ruined my fuel lines under there with rust.
