This is interesting.... The ECU that was still in the car is an old style and it has all the pins on the ECU connector...weird
post-29917-0-01304700-1425770221_thumb.j
This is the older ECU style that was in the car.
post-29917-0-11831200-1425770404_thumb.j
This is the most modern of the ECU styles with less pins.
post-29917-0-98523600-1425770471_thumb.j
The pins aren't connected to anything inside are they?  Probably pre-made connectors, wasteful manufacturing.  Maybe ran out of the other stock and used those to finish an order.  I have one of each of those too, a full set and one pinned to match the diagram.
Interesting that there are now three styles of the mystery parts - black cooling fins, raw aluminum, and none.
Thanks much for the pics of that ECU with the DIP packages. Unfortunately no new info. Those are the exact same part numbers that are on the original round heat sinked versions. Still custom, still no datasheets in the public domain, and still made from unobtainium.
So have you tried that newer ECU in the car yet? Just to make sure it works?
Here is info I scavenged, from before Al Gore invented the internets.
cygnusx1, Thanks for that and that's some awesome info, but I don't think it pertains to the first gen Z's. I've been through that stuff from all angles and I believe the work done on those old internets pages is from a different ECU. Might be a ZX, but it's not a first gen.
Haha!! Too bad Al Gore isn't a forum member. I bet he could help with tracking down the origins!  :)
  • Who's Online   1 Member, 0 Anonymous, 1,292 Guests (See full list)
