I'm wanting to install a buzzer and obviously will need to pull power from when the headlights are turned on. I was wondering if there is any way I could avoid cutting into the wiring? I was thinking that maybe I could use the connector from the combo switch. I could fabricate a short stretch with a tee that would insert between the plugs on the combo switch and the dash harness. As long as those stock bullet connectors aren't an oddball size I would think that would work. Thoughts?
https://www.classiczcars.com/topic/51095-headlight-warning-buzzer/
Yeah, I've got one of his parking light harnesses. I would like to have him make me a headlight harness as well but I have to source a harness for a 78 so I can cut the plugs off. If I do that I'll just have him leave me a spare wire for this purpose, but I have to find a harness first.
