Radio Switched Power In The Hatch?
Question for those with relatively intact radio setups in their 240Zs: is there a radio-switched power connection to the rear?
I'm adding a small amplifier with a bluetooth receiver (as well as a couple of modern speakers), while retaining the function of the stock AM radio in my '71, and should the radio switch power somewhere in the back already (maybe the antenna?), it would be fairly convenient to use that to turn the new setup off, when the stock radio turns on.
If not, is there a switched output somewhere on the radio itself that I could run back to the rear?
https://www.classiczcars.com/topic/51180-radio-switched-power-in-the-hatch/
