Hodgimus-maximus Posted April 4, 2015 Share #13 Posted April 4, 2015 you could try sanding it all down to about 1/4 of and inch and glueing high density closed cell polyethylene foam on top of it. Shape the foam so that it looks stock. then glue new vinyl onto of the foam. link to polyethylene foamhttp://www.yourautotrim.com/1thevaclcefo.html?ref=lexity&_vs=google&_vm=productsearch&gclid=Cj0KEQjwl_6oBRDHxNGz6ueJufMBEiQAvm_k_sd6bI4UD0vEVjUNYznpt3OhoABLwZOkFoFDDYJQYm0aAgXA8P8HAQ Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467070 Share on other sites More sharing options...
hr369 Posted April 4, 2015 Share #14 Posted April 4, 2015 +1 vote for full dash cover Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467082 Share on other sites More sharing options...
Phred Posted April 5, 2015 Share #15 Posted April 5, 2015 I live in Gresham Ore. I have a dash free for U-Haul.fly.phred@frontier.com Phred Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467101 Share on other sites More sharing options...
bartsscooterservice Posted April 5, 2015 Share #16 Posted April 5, 2015 Search for a better dash, that's what I would be doing Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467102 Share on other sites More sharing options...
mjr45 Posted April 5, 2015 Author Share #17 Posted April 5, 2015 Yup, a better dash would be a better starting point, after looking a lot more closely at mine, there is so much material missing that I fear it would next to impossible to actually repair, there are lots and lots of small pieces of the vinyl missing, cracked and broken that I would have to virtually cover the entire thing with the bumper repair stuff and then try to return it back to original form. I'm also not real sure that it wouldn't completely disintegrate when I took it out. Thanks.Mike Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467115 Share on other sites More sharing options...
oranngetang Posted April 6, 2015 Share #18 Posted April 6, 2015 Taking a stab at this right now and I think it might be worse off than when I started! Autobody isn't my thing I guess. Filling the cracks will be the easy part, getting it smooth and in the shape you want so that black paint doesn't show where you've done work is the hard part. I vote full dash cover. Honestly my 1/2 dash really wasn't bad at all. Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467184 Share on other sites More sharing options...
Mikes Z car Posted April 9, 2015 Share #19 Posted April 9, 2015 (edited) I am okay with the half cap on my car though I wish the PO had smoothed the glue out a bit before putting the cap on as I can see every line of glue that was used in the form of a slight visible indentation or protrusion, not sure which. Edited April 9, 2015 by Mikes Z car Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467400 Share on other sites More sharing options...
FastWoman Posted April 11, 2015 Share #20 Posted April 11, 2015 ^^^^ I did that when I capped my '75 dash back in the 80's. After a month in the Texas sun, you could see every line of glue. Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467488 Share on other sites More sharing options...
oranngetang Posted April 11, 2015 Share #21 Posted April 11, 2015 Must be different makers of caps, mine is thick enough you could use concrete to glue it on and there wouldn't be a line or bump. Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467491 Share on other sites More sharing options...
78zcar_blue Posted April 11, 2015 Share #22 Posted April 11, 2015 I believe you can do it just take your time and treat it like body work, daunting yes, but give it a shot. I think I may have some photos of mine before and after on this website if not shot me and email an I'll show you my dash how it came out. Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467492 Share on other sites More sharing options...
oranngetang Posted April 13, 2015 Share #23 Posted April 13, 2015 The thing with resurfacing the dash yourself is going to be the tradeoff of factory texture and color. I jumped into my project last week without too much thought and it still turned out fairly well. My best advice is (since you'll be doing a lot of sanding), mix your body filler components and fiberglass resin components together in a ratio to get a pancake batter consistency. It'll partially self level and sand down faster than bondo itself, while taking longer to set up.I'll post a photo off my phone that shows a little bit how the texture turned out. I used an SEM texture spray can and semi gloss black trim paint. I'd recommend two cans of texture and a full can of spray paint. Then consider doing the same to your centre console or at the least, your glovebox door. Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467568 Share on other sites More sharing options...
mjr45 Posted April 16, 2015 Author Share #24 Posted April 16, 2015 I decided to put on a full dash cap and I'm going to source another dash in better shape than mine, restore that dash and then replace mine with the cap. Thanks for all the replies.Mike Link to comment https://www.classiczcars.com/topic/51213-seeking-some-advice-about-the-dash/?page=2#findComment-467830 Share on other sites More sharing options...
