Site Updates this Weekend ×
Can folks please add accurate HG compressed and diameter measurements to this thread.
I have scoured the net for many data points but there is a lot of variance so Id like to start again in this thread to improve the accuracy.
Here is what I have collected:
MFGR_____COMP_____dia
NISMO____0.60mm___???
Ishino___1.00mm___???
Nissan__ 1.14mm___???
Nissan___1.20mm___???
Nissan___1.25mm___???
Felpro___?.??mm___88.9mm
Felpro___1.10mm___???
Felpro___1.15mm___???
Felpro___1.20mm___???
HKS______1.00mm___91.0mm
HKS______2.00mm___91.0mm
Tomei____1.00mm___90.5mm
Tomei____1.20mm___90.5mm
I measured the 88.9mm Felpro on a spare I have. Most state 89mm.
_____________________________________________________________________________________________
Some oval shaped early L24/L26 gaskets are also mentioned but I omitted these as the volume would be difficult to calculate without knowing more details.
FYI:
part number 11044-N4221.
Stamped with the Nissan logo with the code NRZ 46F. NRZ stands for Nippon-Reinz
made in Japan.
oval ring measures 89.5mm x 87mm
features the same water passage holes that original (1971 E31 240z) head gasket had.
https://www.classiczcars.com/topic/51285-accurate-head-gasket-measurements/
I assume that you want the fire ring thickness.  I have an old 76 HG, that I'm pretty sure is the original.  Don't know if it has any ID numbers on it though.
  • Who's Online   1 Member, 0 Anonymous, 719 Guests (See full list)
