Clay Material in Exhaust Manifold - Pics Inside
As I was in the process of pulling the E31 head on my ’71 240z I have been inspecting every part as it comes off.  The engine was rebuilt by the previous owner to stock specs but I have no paper work on it.  The reason for pulling the head is that I cannot get the intake vale #4 in to adjustment.  As I was inspecting the exhaust manifold there is a fair amount of rock hard clay like material on the inside of the manifold.  There is also traces of it in the exhaust pipe but not as built up.  Can someone tell me what this is from?  It appears it would come off rather easily but I have tried chiseling some of it off with a flat head screw driver but it is not budging.  Should I be worried?  Does it warrant buying a new header?
Edited by Hardway
From a book on performance tuning:
I think it initially comes from oil/carbon deposits that were never removed and eventually cooked over the years.  It can initially be deposited as oil from leaking valve seals or passing the rings.  I see similar when I clean the tubes in my oil fired furnace.
post-6852-0-48924700-1430740310_thumb.jp
  • 3 weeks later...
  • Who's Online   1 Member, 0 Anonymous, 1,599 Guests (See full list)
