2 hours ago, jonbill said:
12 hours ago, madkaw said:
Getting close to starting again ! Love the Kameari tensioner set up . Makes life a lot easier to degree your cam
Is that because you can roll it back and forward without losing tension?
Exactly . It’s hard to land right on the valve opening sometimes based on the valve spring tension- but if you miss , you just roll the engine back . Movement is instant thru the chain assembly . You can also turn the motor using the cam bolt - which also simplifies things
  • Like 3
13 hours ago, Reptoid Overlords said:
I've been running my .080 shaved P90 for around 3500 miles now.  I love it and haven't had any problems with pump premium fuel.
Same. Mine has been on and off the road since 2013 with the shaved P90 @ 11:1 compression with no issues related to running California 91 pump gas.
Mine didn’t follow the same CR since I am using custom JE pistons . I figured a bit over 10:1 at this point , but I think I’ll be happy with that. I wanted 11:1 , but I would have to shave another 40 thou of the head probably . My MN head is still in machine shop jail.
So yesterday was first run . Didn’t even bother to install the hood , bumper
I did that too when my new engine fired up for the first time!!! Exactly like you, 30 miles later I was grinning from ear to ear but the whole time I was totally expecting to be stopped by the Police!!![emoji1787]
Congrats dude!! Such a good win when that happens. That power band sounds great and tractable. [emoji106][emoji106][emoji106]
I was told by my engine builder to check head-bolt torque and valve after the first 100 miles, 300 miles, 500 and so one while the head gasket and everything else settles.
  • 5 months later...
What’s your max ignition timing 100kpa
  • Who's Online   2 Members, 0 Anonymous, 1,435 Guests (See full list)
