Finally took it upon myself to rebuild my 1970 240z L24 engine. Nothing too wild. Went .20 over, installed new seats, valves, springs, bearings, ARP head studs, main studs, rod bolts and clutch bolts (yes. overkill, But I want to trust the engine).
Finishing up gapping the rings, and installing them. Bearings and crank should be installed by the end of this weekend.
The Datsoon marches on.
10981811_10100476823269376_605094400477610985439_10100476823284346_7690743422827
More to come as it all comes along.
https://www.classiczcars.com/topic/51504-building-my-l24/
Stock cam, Stock valve size. Pistons came from ITM. Nothing crazy, just a overbuilt factory rebuild.
Not my first time building a engine, just first time building one for myself. I'm doing as much as I can to get it built quick and back on the road as soon as possible. But not skipping anything and taking time. This weekend im cleaning surfaces and polishing parts. Hope to have the pistons in the block by mid week.
https://www.classiczcars.com/topic/51504-building-my-l24/#findComment-469922
Well, Went around to gapping rings, and installing bearings today. Cleaned everything then installed bearings, coating them in redline assy. lube. Then took about to painting the block. Laid down multiple coats of a primer with ceramic in it. Once that had dried laid down coats of Datusn engine paint, sourced from Datsun parts.
Turned out looking great, if I do say so myself.
11206954_10100478833590676_7942538742688
https://www.classiczcars.com/topic/51504-building-my-l24/#findComment-469937
  • Who's Online   2 Members, 0 Anonymous, 1,280 Guests (See full list)
