When I looked at the advance curves spreadsheet that Walter Moore put together I saw that he recommended against the 80-83 distributors because the mechanical and vacuum advances together were potentially dangerous, so I was prioritizing the 79 in my search.
However, I have found one or two errors in that data so maybe it’s not the case.
Edited by Matthew Abate
I did not know that. Everything I’ve read about this pushes the ‘79 specifically.
It’s been maybe 27 years since I rebuilt a distributor so I kinda forgot how they work. Clearly I wasn’t paying attention that day in class. I’ll dig into it.
i still want to know what people are asking for one, though. What I’ve found online isn’t great, but I’ve found a bunch of scrap yards quoting $40 to 125.
Depending on your build you might not want tor need the vacuum advance . I didn’t run one and ran between 17-20 degrees initial and had 35-38 all in . Ultimate would be a compromise between mechanical and vacuum , but if there is probably going to be a failure in any part of those dizzies it’s the vacuum advance .
Here's a quick recap of the engine @Takhli is building me:
  • F54 block with 87mm bore
  • L28 Crank with factory 79mm stroke
  • L24 connecting rods (133mm long)
  • P90a head converted to static rocker pivots
  • CompCams Stage 1 camshaft
  • Custom JE pistons designed for 9.80:1 compression and relieved for valve clearance
  • Round-top SU carburetors on a European balance tube
  • Various other optimized parts (flywheel, etc.)
  • Deleted smog system
Things I may do in the future (if I don't do them for the initial build):
  • Replace the mechanical fuel pump with an electric one
  • Switch to FI
  • Switch to COP/DIS
11 minutes ago, 240260280 said:
Stock bore and stroke?
  • 87mm bore
  • The crank is from the L28 F54 block, so factory 79mm
  • The L24 rods are 133mm long
  • The pistons are designed around these mods and the P90a head and relieved for valve clearance.
Edited my previous post for clarity.
  • 3 months later...
  • 3 weeks later...
