Captain Obvious Posted July 5, 2015 Author Share #61 Posted July 5, 2015 Namerow, Forgot to ask... Does this plug-n-play diagram agree with what you were intending to construct? Other than the early pigtails using a black wire between the main harness and the bulb prongs, does everything look right and make sense? Link to comment https://www.classiczcars.com/topic/51554-a-different-headlight-relay-upgrade-4-relays/?page=6#findComment-473222 Share on other sites More sharing options...
TomoHawk Posted July 5, 2015 Share #62 Posted July 5, 2015 I had to check the color twice, and even clean the dirt off both to make sure I got it right. According to my 1978 wiring diagram one set should have a RY wire, but both were the same, as I had posted. Link to comment https://www.classiczcars.com/topic/51554-a-different-headlight-relay-upgrade-4-relays/?page=6#findComment-473223 Share on other sites More sharing options...
