CDL1542 Posted October 6, 2015 Author Share #13 Posted October 6, 2015 And under the ITG filters are some shiny stacks and a heat shield from datsun spirit. All of them fit together very nicely! I have a black wrinkle coated valve cover with brushed letters for this too. 1 Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478613 Share on other sites More sharing options...
Chickenman Posted October 6, 2015 Share #14 Posted October 6, 2015 Very nice work. You should be proud of your accomplishments!! 1 Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478624 Share on other sites More sharing options...
rcb280z Posted October 7, 2015 Share #15 Posted October 7, 2015 Wow! Very nice! One detail that requires your attention. Your front side marker lights need to be turned 180. The wider part of the lens faces to the front. But other than that, Im jealous man. What a nice car. Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478647 Share on other sites More sharing options...
Pmg Posted October 7, 2015 Share #16 Posted October 7, 2015 Yeah, it looks great. Btw, what did you do with the holes where the original side mirror was mounted? PMG Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478649 Share on other sites More sharing options...
Travel'n Man Posted October 7, 2015 Share #17 Posted October 7, 2015 Looks great - keep us posted Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478656 Share on other sites More sharing options...
CDL1542 Posted October 7, 2015 Author Share #18 Posted October 7, 2015 Very nice work. You should be proud of your accomplishments!! Thank you!Wow! Very nice! One detail that requires your attention. Your front side marker lights need to be turned 180. The wider part of the lens faces to the front. But other than that, Im jealous man. What a nice car. I'll have to flip them asap. I'm surprised I never caught that, I guess you learn something new every day. Yeah, it looks great. Btw, what did you do with the holes where the original side mirror was mounted?PMGThe holes in the door skin are still there and I don't know if I want to fill it or not considering that I'd have to do paint to cover it and that's not my plan for it.. Right now I have a piece of thick flexible plastic that's cut cleanly to shape and bolted down through the holes. It's soft enough that it sucks down against the door and creates a seal too. I might take a piece of aluminum or G10 (composite material) and shape a more permanent solution later on. The black plastic doesn't look too bad though. Looks great - keep us postedWill do! Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478679 Share on other sites More sharing options...
CDL1542 Posted October 10, 2015 Author Share #19 Posted October 10, 2015 This is what the rubber strip looks like right now: And the first of the two drums is rebuilt with some new pads: Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478843 Share on other sites More sharing options...
Pmg Posted October 11, 2015 Share #20 Posted October 11, 2015 Looks good actually, not a bad way to cover up the holes. PMG Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478854 Share on other sites More sharing options...
gundee Posted October 11, 2015 Share #21 Posted October 11, 2015 What shock is TTT using in their kits now?Still Koni? Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478859 Share on other sites More sharing options...
CDL1542 Posted October 11, 2015 Author Share #22 Posted October 11, 2015 What shock is TTT using in their kits now?Still Koni?Yep, they're Koni shocks with Eibach springs. Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-478861 Share on other sites More sharing options...
CDL1542 Posted December 16, 2015 Author Share #23 Posted December 16, 2015 Been a while since I've given any update but progress is updated regularly here if you want to check anything out. I decided to go with an auxiliary fuse box and am really thrilled with how easy it is and how simple it will be to add anything from this point forward : https://www.instagram.com/allaboutthez/ Here's the latest! Wipers, dome light, map light, horn, antenna, radio, (and a clock shortly) are all working! Going to swap the engine in a couple weeks. 2 Link to comment https://www.classiczcars.com/topic/51559-going-coilovers/?page=2#findComment-482982 Share on other sites More sharing options...
