The clevis's are welded to the strut tower and a plate on the firewall.  It was all custom and is not available as a bolt-in.  In general, bolt-in chassis reinforcement doesn't work that well.
Lots of other custom work in the pic:
Radiator mount
Radiator
Cooling system routing
Cooling system overflow
Intake manifold
Throttle body
CAI
Brake MC bracket
Edited by John Coffey
Yes, the booster is deleted using the bracket and Tilton balance bar I used to make and sell.  It allows mounting of two master cylinders, one for the front system and one for the rear system.  That, in conjunction with the balance bar and an adjustable prop valve for the rear system let me dial in the brake balance.  Brake pedal pressure was perfect (for me).
  • Who's Online   1 Member, 0 Anonymous, 1,318 Guests (See full list)
