SilverSurfer Posted June 30, 2015 Share #1 Posted June 30, 2015 (edited) Hello! I am looking to purchase new wheels for my '77 280Z. I am running 205/55R16 tires (and they are virtually new), so I will be going with a 16" rim, most likely with a 7" depth. Here is my question:What is the max offset that I can use? I would prefer zero offset, but the wheel selection at zero offset is limited. Before I really start to shop, I would like to know what my ranges are for offset, if possible. I already know the bolt pattern, etc.Thanks in advance for any help! Edited July 1, 2015 by SilverSurfer Link to comment https://www.classiczcars.com/topic/51759-wheel-offset-max-pos-or-neg-for-77-280z/ Share on other sites More sharing options...
racer47201 Posted July 1, 2015 Share #2 Posted July 1, 2015 I have Koenig Rewinds 16 X 7 on my 77 2+2 with 0 offset IIRC. No rub no problem. I like them. Bought all 4 plus 4 Michelin 205R16 installed,balanced with lugnuts from Discount Tire online for 1000 even no sales tax. I was pleased. Link to comment https://www.classiczcars.com/topic/51759-wheel-offset-max-pos-or-neg-for-77-280z/#findComment-472996 Share on other sites More sharing options...
SilverSurfer Posted July 1, 2015 Author Share #3 Posted July 1, 2015 Thanks. I appreciate the reply. I was looking at the Koenig Rewinds myself, but there are others I like better. That's why I was asking about the offset. I know that zero offset is ideal for the '77 280Z. But I wondered if any of the other offsets worked as well. Link to comment https://www.classiczcars.com/topic/51759-wheel-offset-max-pos-or-neg-for-77-280z/#findComment-473001 Share on other sites More sharing options...
Jeff G 78 Posted July 3, 2015 Share #4 Posted July 3, 2015 You need to stay close to zero (about -6 to +6) unless you plan on running spacers. Most aftermarket wheels are for modern cars which use closer to +35 and up offsets. Those will not work without bolt-on spacers and they don't look right on a Z. Link to comment https://www.classiczcars.com/topic/51759-wheel-offset-max-pos-or-neg-for-77-280z/#findComment-473143 Share on other sites More sharing options...
