Ok, i am sure that it is something simple, but a mechanic i am not!
I droze my Z on Friday, not one thing wrong with it at that time. Parked her in the garage and today, it won't even turn over. I have power from battery, lights work even the annoying buzzer from the ignition works, but the car won't even turn over!!
Starter? Voltage regulator? How do i trouble shoot this??
Please help,
Thanks
Paul
https://www.classiczcars.com/topic/5181-help/
If it won't turn over, it won't be the coil wire....:cross-eye
Sounds more like either a loose battery cable, or a bad connection at the starter. If not that, might be the starter solenoid has gone... or the ignition switch...or....
Did you check your fuses, the "common" 20 amp(depending on your year, lower right corner)?? Do you hear a clicking when you hit the key?
https://www.classiczcars.com/topic/5181-help/#findComment-30244
The 260 also had some cursed "anti-theft" i think they called it- the seatbelts had to be hooked, tranny in neutral, maybe something else i am forgetting. I seem to remember disconnecting the wires that are beneath the seats, and mine wouldn't turn over either, till i plugged them back together.
Been awhile, but you may check it out??
Otherwise i'd try jumping across the starter solenoid like mentioned earlier. Good luck!
https://www.classiczcars.com/topic/5181-help/#findComment-30266
sounds like the connection to the solenoid. My car used to do that all the time. All it did was make the "clicking" sound. I jiggled the connection and it fired right up. The connector had some crud on it, so it wasn't getting good conductivity. I've since put a new connector on it. It could be the starter itself though. Is your starter a rebuild??? I went through 3 of them before getting one that worked.
https://www.classiczcars.com/topic/5181-help/#findComment-30295
