Hi! Steve from Brownstown here. I have a 77 280Z auto that I'm converting to a 5speed from a 82ZX. I wonder if the clutch/brake pedals or assembly is compatable with the 77Z. Also have extra parts from the 82ZX available. All the glass is good. The body is rusted, however it had almost new fenders on it. Still can read the made in Taiwan stickers on them. Thanks if you tell me about the compatability with the clutch/brake assembly.
https://www.classiczcars.com/topic/51917-280zx-pedals/
If you are stripping it don't forget the engine and its components like:
alternator - should be a 60 amp internal regulator version. Its bigger than the 77 280Z.
distributor with internal ignition unit.
webbed inlet manifold in rumorred to be better againsg hot start issue.
fuel pump back ag the tank. The fuel pump configuration is a little different but all the essential parts are the same.
https://www.classiczcars.com/topic/51917-280zx-pedals/#findComment-474221
