TomoHawk Posted July 23, 2015 Share #1 Posted July 23, 2015 These were discussed on the Ztrix website, as a way of putting bigger/wider wheels on your Z without buying custom wheels. I have never heard much good about spacers, but these hub extenders seem different, so I wanted to ask. FYI, I don't plan on any serious racing, but may do an occasional lap on a course if I get a chance- just not that quickly For more details: http://www.ztrix.com/frequently-asked-questions/wheels-and-tires.html Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/ Share on other sites More sharing options...
grannyknot Posted July 24, 2015 Share #2 Posted July 24, 2015 Interesting site, at one point I was trying to find a way to put 5 bolt, +25 offset wheels on the Z,I was quoted $450 for custom hub extenders with a min. thickness of 1.5".I didn't go that direction but these hub extenders open up a whole range of wheels that we could never consider before, and they are inexpensive.I wouldn't be racing on them either, although I would probably knock out the studs on the extender and install longer studs mounted in the Z hub that would just pass through the extender making it into a spacer.Chris Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474399 Share on other sites More sharing options...
anthony_c Posted July 24, 2015 Share #3 Posted July 24, 2015 i've never heard of them referred to as hub extenders, but google "wheel adapters" and you should find many sources and just about any dimension you could dream up.typical price is about 40-50 per wheel.you may need longer studs up frontpay attention to the hub bore.i'm running a set now. they work, but i'd feel more confident if they weren't there. Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474414 Share on other sites More sharing options...
John Coffey Posted July 24, 2015 Share #4 Posted July 24, 2015 If they are properly made and installed correctly you shouldn't have any issues other then an increase in scrub. Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474416 Share on other sites More sharing options...
TomoHawk Posted July 25, 2015 Author Share #5 Posted July 25, 2015 What is 'scrub?' Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474457 Share on other sites More sharing options...
Patcon Posted July 25, 2015 Share #6 Posted July 25, 2015 Tire "scrubbing" the wheel arch Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474462 Share on other sites More sharing options...
Jeff G 78 Posted July 25, 2015 Share #7 Posted July 25, 2015 Tire "scrubbing" the wheel archUhhh, no. Scrub is the arc that the tire makes on the ground when the wheels are turned. The hub turns on the strut axis and if the wheels are pushed out, the tires will travel in an arc on the ground rather than simply rotating in place. That said, wheel spacers don't necessarily increase the scrub radius. If you install 40mm spacers and then use a +40mm offset wheel, the scrub radius is the same as stock. Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474493 Share on other sites More sharing options...
anthony_c Posted July 26, 2015 Share #8 Posted July 26, 2015 jeff's response sort of begs another question. one mechanic i spoke with seemed to think that my 16x7 +38 rims combined with 38mm wheel adapter would be stressing the bearings.but unless i'm overlooking something, i've effectively maintained the same centerline, so there should be no problem. am i correct? Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474518 Share on other sites More sharing options...
Jeff G 78 Posted July 26, 2015 Share #9 Posted July 26, 2015 jeff's response sort of begs another question. one mechanic i spoke with seemed to think that my 16x7 +38 rims combined with 38mm wheel adapter would be stressing the bearings.but unless i'm overlooking something, i've effectively maintained the same centerline, so there should be no problem. am i correct?Correct. The bearings do not know the difference. The loads would be exactly the same as if you use zero offset wheels. Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474520 Share on other sites More sharing options...
Patcon Posted July 26, 2015 Share #10 Posted July 26, 2015 Thanks JeffG Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474521 Share on other sites More sharing options...
TomoHawk Posted July 26, 2015 Author Share #11 Posted July 26, 2015 Scrub could probably mean both things, depending on the context. my 16x7 +38 rims combined with 38mm heel adapter So, which kind of offset is the positive number and negative number? It gets confusing. Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474529 Share on other sites More sharing options...
Jeff G 78 Posted July 26, 2015 Share #12 Posted July 26, 2015 Positive offset pushes the wheel inward and has a more flush face look. Negative offset gives the wheel a deeper dish. Modern cars have +40 - +60 offset. Near zero offsets are extremely rare these days. Link to comment https://www.classiczcars.com/topic/51934-hub-extenders/#findComment-474531 Share on other sites More sharing options...
