Hey everyone.
I live in Colorado, and I use my Z as a daily driver. Its a 1983 280zx Turbo, T-tops ect.
Recently this winter slid on the ice into a curb at probably about 20 MPH.
Moral of the story is driving Z's in the snow sucks. I bent the frame a bit. I have a wrinkle in the frame behind the wheel on the right front side. I can add pictures alter, but I am at work.
At first I thought it was the steering rack, but it is just the frame (could be better could be worse) My Z is pretty rust free, but the frame is still a bit of a worry.
Would it be recommended to just see what can be done with a standard frame machine?
Or should I look into offsetting with adjustments to the A-arm?
Recommendations welcome.
I ultimately want to strip the undercoating that is currently there and re-coat it with POR-15 or something similar.
If possible I'd also like to reinforce the frame rails, just for performance purposes, I do not intend to swap or do much other mods, I am keeping it stock as mechanically she is a dream with only 145k original miles.
I also need to replace the fender (Driver's front Quarter) Which I can get cheap, but I was curious as to the process of replacing. (Frame is more important at the moment)
Any recommendations are appreciated!
Thanks!
https://www.classiczcars.com/topic/52039-frame-work/
