1157 bulb socket dilemma solved....for now.
So in a different thread I was on a search for 1157 bulb sockets for my 77 280. Didn't find originals but after purchasing a couple different  41NhXZVSCfL._AA160_.jpg41bBukSAP9L._AA160_.jpgtypes to try and then realizing they aren't going to work, I decided to take these apart and compare them to the stock one. Neither one of these 2 pictured would work as far as fitting tight in the tail light housing. The white sockets pictured would fit but not snug like the stock ones. And the "sockets" were shorter than stock as shown here post-20387-0-49728000-1441557286_thumb.j. So I decided to pull the spring, spring plate, and 2 wires out of the new socket post-20387-0-07171500-1441557442_thumb.j and splice into the original socket housing. Was also able to use the new rubber gasket that was supplied with the aftermarket ones as you can see in the first pic. So I was able to use the original housing and socket but installed the new wires, spring and plate pictured in the last pic I posted. Hope this helps anyone having the same issue.
  • Who's Online   2 Members, 0 Anonymous, 1,292 Guests (See full list)
