Alan2fast Posted September 9, 2015 Share #1 Posted September 9, 2015 Ok guys still new here as you guys probably seen just got my 73 240z running but when i give it gas to fast it wants to choke out and almost die and back fires out of the front carburetor. Carburetor were just fully built. Since the frist start i let it run for 15min in idle then reved the motor up and did fine so i took it for a drive and it was hard to get power unless i slowly give it gas then its good after and when i turn the car off the motor shakes hard feels like it wonts to stay on still Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/ Share on other sites More sharing options...
Alan2fast Posted September 9, 2015 Author Share #2 Posted September 9, 2015 Here is a short video Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477252 Share on other sites More sharing options...
siteunseen Posted September 9, 2015 Share #3 Posted September 9, 2015 After rebuilding the carbs you'll have to fine tune the adjustments. Here's a helpful write up from member Blue, if they are SUs.http://www.classiczcars.com/topic/39221-quick-and-dirty-su-tuning/ Hope that'll help. You'll have to upload the video to youtube then link it here. Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477260 Share on other sites More sharing options...
rossiz Posted September 9, 2015 Share #4 Posted September 9, 2015 blue's info is excellent. if you're running su's, it is a fairly straightforward process.be sure you have adequate fuel supply to the carbs (pump, filters) then number 1 above all is float levels - get 'em right, or you'll chase your tail w/the other adjustments. Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477262 Share on other sites More sharing options...
beermanpete Posted September 9, 2015 Share #5 Posted September 9, 2015 Make sure you have oil in vacuum piston dampers. There is an endless debate on what oil to use but 10W30 is a good place to start. Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477263 Share on other sites More sharing options...
Alan2fast Posted September 9, 2015 Author Share #6 Posted September 9, 2015 Thanks guys blues info lookes good ill get right to it and as far as the damper oil 10w30 what type of oil are we talking im runing 3in1 Sent from my SM-N900T using Tapatalk Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477269 Share on other sites More sharing options...
siteunseen Posted September 9, 2015 Share #7 Posted September 9, 2015 I've only used the blue label 3in1 myself. When everything else is working right I'm going to try different oils. Here's my short list, ATF, John Deere hydrostatic 20 weight, 10w30. I need to read more into it though as far what thickness works best for the weather around here. The 3in1 is working good so far but I don't know what to compare it to. If you're going to keep your carbs I'd spend $30 on one of these, ebay or amazon has good prices. Takes the guessing out of the process. Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477273 Share on other sites More sharing options...
Alan2fast Posted September 9, 2015 Author Share #8 Posted September 9, 2015 Im running the red label 3in1 and what do you call that and whats it for thanksSent from my SM-N900T using Tapatalk Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477275 Share on other sites More sharing options...
siteunseen Posted September 9, 2015 Share #9 Posted September 9, 2015 The blue label is straight 20 weight and thats what nissan reccomends. Bought mine at Lowes. Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477276 Share on other sites More sharing options...
Alan2fast Posted September 9, 2015 Author Share #10 Posted September 9, 2015 Ok change what i have and here is a link to one off the videos https://youtu.be/Z_0zgMAmiN4Sent from my SM-N900T using Tapatalk Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477277 Share on other sites More sharing options...
Alan2fast Posted September 9, 2015 Author Share #11 Posted September 9, 2015 https://youtu.be/7MR9OCY10A4Sent from my SM-N900T using Tapatalk Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477278 Share on other sites More sharing options...
Alan2fast Posted September 9, 2015 Author Share #12 Posted September 9, 2015 https://youtu.be/7XeLfyQi4TASent from my SM-N900T using Tapatalk Link to comment https://www.classiczcars.com/topic/52330-240z-low-power-cuts-out/#findComment-477279 Share on other sites More sharing options...
