That's what I've done several times.  Use a metric machine screw of the proper thread (I found mine at Ace Hardware) and grind the round head flat on two sides so it looks like a "T"  Stick the head end into the hole where the previous stud was and add epoxy - or fill the hole with epoxy and then inset the new screw/stud. The "T" end embedded in epoxy will keep it from spinning when you put the nut on and also from pulling out.
Dennis
Edited by psdenno
  • Who's Online   2 Members, 0 Anonymous, 1,145 Guests (See full list)
