Altenate location to install horns on a 1972 240z
I am in the middle of the AC installation on my 240z and due to the fact that i had to install an electric fan in front of the ac condenser, i will need to relocate the horns from their original location to elsewhere or change their position in a way! Any recommendations on where to place them? They will need to be near or else the connnecting wires wont reach the horn terminals.
I just put some spacers between the horns and the frame, and used longer bolts, to clear the fan. Lengthening the wires should not stop you. Just make small extension cables with 1/4" spade connectors. Then its reversible to stock without modification.
Or how making an angle bracket, or mount them upside down?
Thanks ZKars! Got the picture!!
Asides from the above, i noticed that after the dashboard was mounted back there were several issues that needed some more attention to be addressed as follows:
1. The ignition lock key was not returning to the lock position. Could the lock be mounted in a wrong position?
2. The red brake light is not lighting up
3. One of the tail lights marker is not marking.  On the front it does work on the rear one does not mark when activated.
How do i troubleshoot and solve these issues?
Edited by jalexquijano
