AC installed and working but several electrical problems
Went to pick up my car this morning and found several issues which need to be solve. Guys who installed the AC did not pay attention when installing the AC and left some gremlins on its way out:
1. The headlights are on all the time. You start the car and the headlights turn on immediately. Before it took the car to the shop, the headlights could only be turned on when you actívate them by turning the TS Combo switch.
2. The front parking lights do not work. Both bulbs are okay.
3. The Choke light does not work either. THey installed the choke cable bracket: https://www.californiadatsun.com/interior/240z-choke-cable-bracket.html. when you pull the choke, the yellow light does not actívate.
4. The blue high beam light is on when you turn the key to accesories. It should be off, if the last time you used the car you left it off.
Note: I formerly installed both Dave Irwin´s marvelous circuits. The headlight upgrade and the parking light upgrade.
Can i solve these issues by myself and how??
You should take it back to the people that caused the problems. It is not possible for us to figure out what was done as it involves a bunch of custom work and changes. Did they remove the dash? Very likely they did hook up the wiring properly or completely when they put it back together
If you installed it, you should be able to put it back the way you installed it before.
Personally I wouldn't let them touch the car again.
"Note: I formerly installed both Dave Irwin´s marvelous circuits. The headlight upgrade and the parking light upgrade."
There's a small switch where the choke bracket is under the console that activates that light.  If the wire to it gets disconnected the light will not work.
EDIT:  There's two wires, red with a blue stripe and solid red.  Mine broke loose.
post-23570-0-73850800-1445772076_thumb.j
This is where yours may be unplugged, on the driver's side under the console.  You have to unplug that connector to remove the console.
post-23570-0-57627000-1445772253_thumb.j
  • Who's Online   2 Members, 0 Anonymous, 492 Guests (See full list)
