I am starting a new thread for my restoration.  I'll link to other work I have done.  I didn't like the title of the other one and the typo annoyed me.
I have finished with the driver side door and light scoops.  The passenger side scoop was an ebay acquisition that needed a lot of love.  Too bad I don't have a before picture.
Enjoy!
post-22075-0-14023300-1450055589_thumb.jpost-22075-0-35472600-1450055598_thumb.jpost-22075-0-73579900-1450055607_thumb.jpost-22075-0-75864800-1450055616_thumb.jpost-22075-0-97254400-1450055625_thumb.jpost-22075-0-44495200-1450055635_thumb.jpost-22075-0-31410800-1450055644_thumb.jpost-22075-0-23248300-1450055653_thumb.jpost-22075-0-34450300-1450055662_thumb.jpost-22075-0-48573000-1450055671_thumb.jpost-22075-0-54166900-1450055774_thumb.jpost-22075-0-69793700-1450055780_thumb.jpost-22075-0-90931800-1450055786_thumb.jpost-22075-0-69054200-1450055793_thumb.jpost-22075-0-35293800-1450055800_thumb.jpost-22075-0-99452900-1450055808_thumb.jpost-22075-0-54035200-1450055818_thumb.j
https://www.classiczcars.com/topic/52974-kens-280z-resto-thread/
Here's some old stuff just to make my thread complete:
Rear suspension rebuild - this is the first thing I did to the car before I decided it needed a rotisserie restoration:
http://www.classiczcars.com/topic/45155-rear-suspension-rebuild-thread/
Front suspension rebuild:
http://www.classiczcars.com/topic/45331-front-suspension-rebuild-thread/
Fuel Tank repairs:
Edited by ksechler
Some updates...
The updates will be slower now since I'm current.  So everything I post will be as I complete the work.  I have been working on the hood.  Stripped it inside and out then sprayed Eastwood internal frame coating everywhere that I could not reach.  I am doing the blocking and filling now...
post-22075-0-17445900-1450741849_thumb.jpost-22075-0-09507600-1450741850_thumb.jpost-22075-0-94728000-1450741850_thumb.jpost-22075-0-77799300-1450741851_thumb.j
Some work on fender flares...
These are the MSA fiberglass flares.
Screwed on (front and back):
post-22075-0-51983500-1450741985_thumb.jpost-22075-0-11380200-1450741988_thumb.j
I traced the fender flare outline:
post-22075-0-35196900-1450741986_thumb.j
Stripped the fender back to bare metal:
post-22075-0-16839800-1450741987_thumb.j
Sanded the flare to rough it up to glue on, fill, primer, etc. The left one is sanded the right one is not:
post-22075-0-99544300-1450741988_thumb.j
And glued the suckers on:
post-22075-0-94152800-1450741989_thumb.jpost-22075-0-83026200-1450741990_thumb.jpost-22075-0-72319400-1450741991_thumb.j
I used 3M panel adhesive.  Interestingly I found out that you needed a special gun to apply.  It's only $200!  Yikes!  So I squeezed the contents into a cup and mixed it by hand before applying it manually.
The next step will be to apply fiberglass to further secure everything in place and then fill and sand until I get the contour I like.
Time for an update! While Santa's elves might have been getting ready for the big night, I was working in a workshop of my own!
My boss told me to go home early for the holiday around 1:00 yesterday, "Yes Sir!!" I said.  Kids were at their grandmothers' so it's just me, myself and I.  Naturally, I ended up in the garage with my best (metallic) buddy.
Time to start blending the fender flares.  How to fill those ugly screw holes? I filled the holes with glass impregnated filler.  Then I put a piece of wax paper over the mess and smoothed it out.
post-22075-0-40137400-1451077319_thumb.jpost-22075-0-29115800-1451077320_thumb.j
Then just did a lot of filling and sanding.  When I have the right contour I will put a layer of fiberglass overtop and then smooth everything out with normal filler.  I have tried a variety of products, but I really love the Eastwood fillers.  They are very workable and don't have the initial stickiness ( which loads up sandpaper instantly) other products have.
post-22075-0-16371100-1451077321_thumb.jpost-22075-0-03384400-1451077322_thumb.jpost-22075-0-91063000-1451077322_thumb.jpost-22075-0-77923300-1451077323_thumb.jpost-22075-0-66125300-1451077324_thumb.jpost-22075-0-54344300-1451077325_thumb.jpost-22075-0-47186200-1451077326_thumb.jpost-22075-0-55777800-1451077336_thumb.jpost-22075-0-45364000-1451077337_thumb.jpost-22075-0-32174500-1451077338_thumb.jpost-22075-0-21272000-1451077339_thumb.j
  • Who's Online   1 Member, 0 Anonymous, 946 Guests (See full list)
