Parting out 1973 240Z
  • 1 month later...
You can still get some of them from the dealer (looks like 16 tooth is NLA from Courtesy though).  Not sure how, exactly, to get the right part number, but they are out there.  But you need to specify which transmission you're using.  4 speed, early 5 speed, late 5 speed?  The early and lates use a different housing, but you can always just swap the plastic gear and shaft..  The last number is the tooth count.  Here are some examples.  Don't forget that the tooth count matches the rear diff ratio, not the transmission.
http://www.courtesyparts.com/oe-nissan/3270258s18
http://www.courtesyparts.com/oe-nissan/3270258s17
http://www.courtesyparts.com/oe-nissan/3270258s19
http://www.courtesyparts.com/oe-nissan/3270258s16
http://www.nissanpartsdeal.com/parts/nissan-pinion-assy~32702-58s16.html
I think those numbers are for the late 5 speed.  These seem to be the early numbers.  Looks like the 16 tooth is available for early, if the numbers are right.  Short answer - the dealers still have access to a lot of old parts.
http://czot.org/forum/showthread.php?1760-Speed-Pinion-Gear-and-Housing-Combinations-(-70-78-240-260-280Z)
http://www.courtesyparts.com/oe-nissan/3270378100
Edited by Zed Head
On ‎9‎/‎3‎/‎2016 at 9:07 PM, Jeff Z said:
I need a 16 tooth speedometer pinion gear. If your Z is a 4-speed, that's what you should have. If yours was working and you want to sell it, let me know My zip is 04363. Thanks.
I have sold the car, so I only have a few parts left.  I do not have that part.
  • 5 months later...
  • Who's Online   0 Members, 0 Anonymous, 1,459 Guests (See full list)
