  • 1 month later...
On 1/30/2017 at 10:10 PM, txvepr said:
Got it painted!
fellow Texan here with a 280Z - enjoying your build and cant wait to hear about it firin up!
what'd you coat your headers with? i like that look :)
Edited by FunkytownZ
  • 1 month later...
Out with the old.
Up, Up, and Away!!
Of course, I like to dump all the old oil out on the garage floor, just to make sure its all out of there , of course....
(I used a rubber oil plug due to stripped threads on oil pan. , Just don't get it caught on the sled you put it on.)
Old and New.
Edited by txvepr
So to re-cap, I am at 500 plus miles of breakin. I did a compression check last weekend and was a little worried. My pressure was showing 95psi on all cylinders.
This was giving me a fright. I was worrying about if I had done something wrong, used the wrong rings, etc.....but it was driving fine.
Then I read a short post of someone else having low compression with a build, and someone just threw out there to use the short connector on their pressure gauge.  I had been using the handy long hose that came with mine too. So watch out for Harbor Freight pressure gauge with the hose attachment...
So tonight I used the short metal tube, and sure enough, it shows 150 psi on all cylinders! Woot!!
So I can now sleep at night.  Oil change next.
Cleanest Head in the County!
Edited by txvepr
compression also depends on what camshaft you have. i have a long duration cam, and am only getting about 105lbs on a check, and am running about 9.8-1 compression, but all cylinders are even.
here is a good link  http://www.badasscars.com/index.cfm/page/ptype=product/product_id=68/category_id=13/mode=prod/prd68.htm
Question, with the headers, I have noticed after medium to heavy acceleration,  and then getting off the gas, that I hear small 'backfiring' ,popping?
Is this an indication of a too rich condition, or normal when going from stock exhaust manifold, ?
Maybe this was happening but not heard due to the stock manifold ?
Thanks.
  • Who's Online   0 Members, 0 Anonymous, 1,237 Guests (See full list)
