SOLD 240Z early 260Z BC br coilovers (1969 to 1974)
For Sale New in Box BC Coilovers for 1969 to 1974 S30.  Removed from box, but not installed etc.
3 stud camber plate.  Extended camber plate studs.  Normal lowering (not extreme low).
http://jpngarage.com...-69-74-240Z.htm
SOLD
Edited by jmhtx
They'd probably bolt in but the spring rate might be too low, and the ride height, depending on where you wanted it and tires used, etc.  You'd be starting at a lower spot if you used these in a 280Z.
I was under the impression that the transverse link (aka control arm) did get beefed up for the later cars but the dimensions were the same.  The spinlde pin itself appears to have gone unchanged.
http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension
  • Who's Online   1 Member, 0 Anonymous, 1,414 Guests (See full list)
