Background:
I removed the rear bumper from my early 260Z. In order to do this, I had to drop the tank. The larger vent hoses had been replaced some time in the past with regular fuel hoses. Before putting the tank back into place, my friends and I replaced the 5/16 inch lines and fuel filter, the 3/8 inch vent hose and the 1/4 inch vent hose. Apparently I cut the 1/4 inch line a little short, but we got it to the expansion tank. I put the fuel back into the tank and filled it later in the evening.
Today I was driving the car around 60 MPH when I noticed a change in the exhaust note going uphill. This was accompanied by a lack of response when I pressed on the gas pedal and some decrease in speed. I stopped the car for a few minutes and tried to get back onto the road. I drove a couple of miles on a surface road. At first the car pulled fine uphill, but it did start losing power later. The engine recovered, and I tried to continue my trip.
The ramp was downhill, and the car accelerated nicely to about 74. That was followed by an uphill stretch. The car was losing power and would not respond to throttle inputs. I got off at the next exit, and when I pushed in the clutch, the car died. It restarted immediately, but hesitated a lot.
I drove the car around for the next hour to detect trends. It would do okay on the surface roads, even going uphill around 65 or so, but it would lose power going uphill on the freeway with a characteristic lean sputtering sound in the exhaust.
I'm going to put the car on the lift and look for kinked fuel and vent lines.
Are there any other suggestions from the peanut gallery?
Thanks!
https://www.classiczcars.com/topic/53415-possible-fuel-starvation/
Take the gas cap off and see how it does? Check the fuel pressure at the carbs. You may have knocked some sediment loose and it's made it's way to the carbs banjo bolt filters.
Good luck, hopefully it's nothing major. Blue was going to Florida and drive a truck back up. Said he may stop through Atlanta. Probably already done it though, been a couple of months.
Duh. The Obvious suggestion would be to put the rear bumper back on. (Just thinking about what changed...)  :P
The symptoms sure support a fuel starvation issue. Works great under lighter load, but the system can't keep up under higher fuel demand conditions. Other than a kinked hose, maybe you stirred up enough crap to clog your new filter already? Is it a clear style that you can have a peek at?
Fortunately, it is. I'm looking around the house right now, trying to find any energy I can use to go out and work on the car.
After I get the car up in the air some, I can maybe get a clue. The good thing is that I stocked up on fuel filters a few years back, just for such an occasion.
Haha! I can't help you find the energy, but I can tell you that I understand completely. I've got my dash out right now to finally install my fancy new PWM dimmer and as much fun as that is, here I sit at the computer instead!
  • Who's Online   0 Members, 0 Anonymous, 1,625 Guests (See full list)
