Looking at the recent thread showing tank vent hose replacement, this reminds me of what I found last year.
The photo here shows the vent hose location above the muffler. That grommet had popped out where
it enters the cabin. I reinstalled and then sealed it up real good. That was it. A real pleasure to drive with
the windows down again. Just another thing to check.
https://www.classiczcars.com/topic/54075-my-exhaust-fume-location/
I finally found my source of exhaust fumes in the cabin as well: the hole through which the electric antenna drain tube exits the rear left fender! The rubber grommet had deteriorated. Replaced the grommet, sealed with with black silicone and the car stopped smelling like a muffler.:D
  • 4 months later...
hey, where is that located exactly?
17 minutes ago, Patcon said:
Inside the left quarter panel behind the interior plastic panel. Down low inside straight below the power antennae
As seen from the ground looking up behind the rear driver wheel.
The drain tube and grommet is on the right
Where did you find the grommet?
Thanks!
  • Who's Online   1 Member, 0 Anonymous, 767 Guests (See full list)
