Jarvo2 Posted March 17, 2016 Share #1 Posted March 17, 2016 Last night I replaced the choke (cold start) cables for the carburetors. They need to slide freely and after 44 years of usage and most likely never being lubricated since new, it was time. After doing some research I found that 0.055" Piano wire is the best option for replacement as its affordable and able to push and pull, which is required. I also have more than enough left over and only paid $4.60.After disconnecting the cables from the carbs and pulling the center console apart, I removed the cables from inside the cabin, then measured the length needed. I left myself an extra foot before I cut the Piano wire. I bent it around the mounting plate and then lubed it very very very good before fishing it back into the housing and reconnecting. I'm very pleased with the results!Link to Piano Wire used:http://smile.amazon.com/gp/product/B002M3JQGC?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00 3 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/ Share on other sites More sharing options...
RyanT67 Posted March 17, 2016 Share #2 Posted March 17, 2016 High carbon steel, eh? Hope it doesn't rust out too quickly - not an issue in a piano, where it won't be exposed to wet conditions, but in an engine bay it will be. Interesting idea, but wouldn't bicycle brake cable be a better choice? 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489412 Share on other sites More sharing options...
CanTechZ Posted March 17, 2016 Share #3 Posted March 17, 2016 6 minutes ago, RyanT67 said: High carbon steel, eh? Hope it doesn't rust out too quickly - not an issue in a piano, where it won't be exposed to wet conditions, but in an engine bay it will be. Interesting idea, but wouldn't bicycle brake cable be a better choice? Bike cables are braided wire and wouldn't work well in this application as it has to push as well as pull 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489414 Share on other sites More sharing options...
Jarvo2 Posted March 18, 2016 Author Share #4 Posted March 18, 2016 My car rarely sees any precipitation, so I'm not worried about the steel wire -- my guess is that's what the original was too. Keeping it well greased helps too. Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489474 Share on other sites More sharing options...
sweatybetty Posted March 18, 2016 Share #5 Posted March 18, 2016 i bought the same wire for my heater control cables. the outer part i bought at a local bike shop. less than $20 for everything 2 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489477 Share on other sites More sharing options...
CanTechZ Posted March 18, 2016 Share #6 Posted March 18, 2016 21 hours ago, Jarvo2 said: Last night I replaced the choke (cold start) cables for the carburetors. They need to slide freely and after 44 years of usage and most likely never being lubricated since new, it was time. After doing some research I found that 0.055" Piano wire is the best option for replacement as its affordable and able to push and pull, which is required. I also have more than enough left over and only paid $4.60.After disconnecting the cables from the carbs and pulling the center console apart, I removed the cables from inside the cabin, then measured the length needed. I left myself an extra foot before I cut the Piano wire. I bent it around the mounting plate and then lubed it very very very good before fishing it back into the housing and reconnecting. I'm very pleased with the results!Link to Piano Wire used:http://smile.amazon.com/gp/product/B002M3JQGC?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00 Dave, thanks for link above. It was very timely as I was just looking for replacement wire for my series 1 choke. About ten years ago I bought a new cable from a local Nissan dealer and all I could get was the choke cable for a '72 car (P/N 18410-E8803). At the time I did not know much about the differences between model years, the new cable is about 2.5" shorter than my original one. I was able to get it installed but the bend in the cable coming from the termination at the top of the carbs is now quite tight and it takes a fair amount of effort to use the choke lever and I have been afraid I might break the fragile plastic knob. I don't want to push my luck so I have been thinking about putting new wire in the old cable sheaths which luckily I kept. Thanks again and hopefully soon I will have a slightly used 18410-E8803 for sale. Mike Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489487 Share on other sites More sharing options...
Duffman Posted March 18, 2016 Share #7 Posted March 18, 2016 Have used lawnmower cable, works well. 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489491 Share on other sites More sharing options...
Jarvo2 Posted March 18, 2016 Author Share #8 Posted March 18, 2016 Regardless of what is used, grease the heck out of it! I even sprayed silicon lubricant into the cable housing. The Piano wire seems to be more flexible than lawnmower cable, so it'll pull/push smoother. 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489494 Share on other sites More sharing options...
Mark Maras Posted March 18, 2016 Share #9 Posted March 18, 2016 Yet another consideration is a mig liner. They're available in many diameters. Last time I bought one it was about $1.00 per foot. 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489497 Share on other sites More sharing options...
CanTechZ Posted March 19, 2016 Share #10 Posted March 19, 2016 (edited) Here's another idea for choke cable wire if you are worried about corrosion: http://www.mcmaster.com/#9495k91/=11m0s0p It has a little lower tensile strength than A228 music wire but it still looks to have good properties and a good price. McMaster-Carr also has Hi-tensile steel music, Here are the specs for comparison to the SS wire above: http://www.mcmaster.com/#9666k68/=11m0vpx This wire does have a phosphate coating which would give a small amount of corrosion resistance and help decrease friction inside the outer cable sheath. Edited March 19, 2016 by CanTechZ 1 Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489638 Share on other sites More sharing options...
Patcon Posted March 20, 2016 Share #11 Posted March 20, 2016 Has anyone "miked" the original cables to see what diameter we are shooting for? Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489652 Share on other sites More sharing options...
grannyknot Posted March 20, 2016 Share #12 Posted March 20, 2016 My choke cables are .055" or 1.4mm dia. Link to comment https://www.classiczcars.com/topic/54131-choke-cable-replacement/#findComment-489661 Share on other sites More sharing options...
