Captain Obvious Posted December 14, 2023 Share #85 Posted December 14, 2023 On 12/11/2023 at 11:06 AM, HusseinHolland said: Do you have any pics of the reel mount under the cover? Presumablay adjusted in some way to allow for the strut brace. I don't have any really good pics showing the belt reels, but i do think I have enough mediocre pics hoovered over the years to hopefully get the idea across. Here's one with the seat belt mount in place: And here's one with the interior stripped and you can see the mounting holes: Hope that helps! Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660188 Share on other sites More sharing options...
HusseinHolland Posted December 14, 2023 Share #86 Posted December 14, 2023 14 hours ago, Patcon said: That's a nice sized compressor! BTW I am so glad you're here posting. Otherwise I would run out of stuff to read and that would be bad! Actually has to go back - they damaged it in shipping, looked fixable at first, then noticed the motor mount plate is bent, pump tube is bent, the drive belt doesn't align, and a fin is broken off one cylinder head. 1 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660195 Share on other sites More sharing options...
HusseinHolland Posted December 14, 2023 Share #87 Posted December 14, 2023 14 hours ago, Captain Obvious said: I don't have any really good pics showing the belt reels, but i do think I have enough mediocre pics hoovered over the years to hopefully get the idea across. Here's one with the seat belt mount in place: And here's one with the interior stripped and you can see the mounting holes: Hope that helps! Thanks CO! I didn't realize there was already a tower brace of sorts in place, I looked back at some interior shoots of mine, and it appears I also have those Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660201 Share on other sites More sharing options...
HusseinHolland Posted December 14, 2023 Share #88 Posted December 14, 2023 (edited) So, Home Depot is going to replace the compressor - what that actually means I have to buy another & return this one to get the refund. Kind of a PITA. The rep I spoke with was very apologetic & helpful though. I said that I felt an additional discount was in order for all the aggravation, wasted day off for the delivery (was supposed to come Tuesday, not Wednesday), etc. She discounted the compressor, and added their 'white glove' service (normally a $200 fee) which apparently is intended to make sure that an item is clear of damage prior to shipment, and again at point of delivery. So, all in all, once I get a good unit, it will be over $400 off the retail price. All I got done after work was setting up the press & anchoring it to the platform I made behind the garage. I'm thinking I'll make an awning/ overhang the width of the garage (about 18') to make the platform more user friendly. I should have room to keep a number of larger items out here, albeit under tarps or covers. Edited December 19, 2023 by HusseinHolland 2 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660207 Share on other sites More sharing options...
siteunseen Posted December 15, 2023 Share #89 Posted December 15, 2023 I bought a big Kobalt twin piston similar to your's. Left it on the pallet but put a rubber mat under the pallet to keep it in place. I didn't want to bolt it down. A couple of moisture traps and a brass drain off the bottom that empties into an old coffee container. Made sandblasting much easier. Also a small moisture trap with fittings to use right before the hvlp spray gun and the sandblast gun. Made things very much easier for me. I think @grannyknot has a small coolant condenser in line with his. One day I'll try and do that. Our humidity is horrible down here pretty much year round. Very nice pump you have there. Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660208 Share on other sites More sharing options...
HusseinHolland Posted December 15, 2023 Share #90 Posted December 15, 2023 (edited) 29 minutes ago, siteunseen said: I bought a big Kobalt twin piston similar to your's. Left it on the pallet but put a rubber mat under the pallet to keep it in place. I didn't want to bolt it down. A couple of moisture traps and a brass drain off the bottom that empties into an old coffee container. Made sandblasting much easier. Also a small moisture trap with fittings to use right before the hvlp spray gun and the sandblast gun. Made things very much easier for me. I think @grannyknot has a small coolant condenser in line with his. One day I'll try and do that. Our humidity is horrible down here pretty much year round. Very nice pump you have there. EDIT - not a bad idea to leave it on the pallet, I could just cut it down & put the rubber pad under as you said. I was going to bolt it to the floor with isolator pads, but that does create issues with drainage. I painted my Fiat in my driveway (in a canopy) 5 years ago using the Husky & a even smaller pump in tandem - I want to be able to paint without worrying about pressure drops mid-spray , which happened several times. I'm retiring from my day job this summer, so I'll have more (uninterrupted) time for projects. I'll probably want to repaint the Z at some point in the future, along with the pickup truck I made. Edited December 15, 2023 by HusseinHolland 3 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660210 Share on other sites More sharing options...
HusseinHolland Posted December 18, 2023 Share #91 Posted December 18, 2023 Replacement cushion (2007) came - looks better than the auction indicated. Cushion & seat heater in great shape. Frame is also painted, - unlike my 2006 version. 2 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660294 Share on other sites More sharing options...
HusseinHolland Posted December 19, 2023 Share #92 Posted December 19, 2023 Modified the passenger seat switch mount point, to accept the driver's switch. The pas switch is $$$, vs. the cheap & plentiful driver's version. I don't care if it has 2 toggles 1 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660343 Share on other sites More sharing options...
HusseinHolland Posted December 26, 2023 Share #93 Posted December 26, 2023 (edited) Back in the 350Z seats into the 280Z. Seat belt reel will (hopefully) be relocated to strut tower, like the later 77-78 280. Welded the rails I made to the 350Z rails, Checking that the seat was level to the car before tack welding. Used an weld mat to protect the interior. Removed to finish the welds. Wired the passenger seat (fore/aft only). Have to wire the seat heater Looks good here I didn't seam weld these. There is a plastic guide rail inside that may (did) survive some heat, wouldn't trust it to survive a bead, especially on top Test fit after welding to check for distortion /displacement due to welding, all good sits level with no wobble in the rails Testing wiring for seat fore/aft. I bought used 350z heater switches, however it will be easier (I hope) to rewire the seat grids to the aftermarket relay & switches I already have in place Full forward setting Seat sits substantially lower than stock height. Furthest possible recline in full rear position Wesco reel will hopefully go here. Does not feel like there is a metal plate under the cover, which may actually make it easier Edited December 26, 2023 by HusseinHolland 3 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660496 Share on other sites More sharing options...
HusseinHolland Posted December 27, 2023 Share #94 Posted December 27, 2023 (edited) As @Captain Obvious predicted - a beating was in order. Not really happy about pummelling the perfectly good and clean tunnel, so I was gentle at first & used a mallet & block of wood to gently invert the bulge. Problem is that there is a major panel overlap seam in the way, forward of the inner seat belt mount, rearward of the stock rear cross member/seat support. Had to break out the large dead blow to reshape that. After the "gentle" mallet work Beating administered. Cleanup & paint to come, on the underside also. Edit - that is glue on the inner forward seat cross member , not Rust! Now the seat can be made level without lifting the sill side Side note - I guess Nissan wanted to build in the rusting process that was mostly resolved on the outside (compared to classic Z's anyway Seat cushion controls clear the sill Inside clearance matches the pas side Slight problem in that the rail spacing is not even left to right - I have to make a wider rail conversion for this side. Fortunately a 2" "U" channel will take up the gap. I don't want to simply cut & offset the bolt down points relative to the rail. Edited December 27, 2023 by HusseinHolland Add text,typo Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660505 Share on other sites More sharing options...
Captain Obvious Posted December 27, 2023 Share #95 Posted December 27, 2023 1 hour ago, HusseinHolland said: As @Captain Obvious predicted - a beating was in order. Sorry to be the bearer of bad news. The beatings will continue until morale improves. 3 Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660508 Share on other sites More sharing options...
HusseinHolland Posted December 28, 2023 Share #96 Posted December 28, 2023 (edited) Had about 40mins. between festivities, so I started on the wider inner seat rail . Need to weld it up, however the basic element is ready to move forward Edited December 28, 2023 by HusseinHolland Link to comment https://www.classiczcars.com/topic/54393-seat-upgrade-350z-seats/?page=8#findComment-660546 Share on other sites More sharing options...
