Aluminum flywheel friction plate
Well siteunseen you will look a bit dumb once in a while when you
stop a the a red light or stop letting go the gas a bit to promtly the engine will stall.
but this is not a big deal. I am putting back my engine in this weekend then allignement next week
And the orange Z of Magog will be back on the streets. So much work done this winter
you woudnt beleive.
not sure the total finished weight of your aluminum flywheels, but i have a 2+2 setup (larger diameter) that i had lightened considerably and while i can definitely notice the motor spins up much more quickly i've never had a problem w/stalling. it idles nicely at 700rpm and on flat ground i can start off without my foot on the accelerator at all. this is, of course an L28 so maybe a bit more torque than the L24 i suppose...
