I decided to go a head at get the black pinion gear for the speedo, I was going to swap with the old 4 speed but that seemed like more work than needed, as I would like be ready to go when I get it out.
Next snag, removing the bolts at the bottom of the exhaust manifold so I can swing the exhaust pipe out of the way. I have been hitting them for days with PB blaster, tried a box wrench, not even a budge, that was just from the top to see if anything would be easy.
I have been researching how to get them off. I think the best solution IF I can get it to fit would be a nut splitter. After that a oxy/ace torch and heat would be next (some show wax being used like flux on the hot parts). I do have an electric impact wrench. I can get a torch setup for around 200$ seems like a handy thing to have anyway.
 Those studs can be the worst part of pulling a trans. The nut splitter is a good idea. Let us know how it works. I broke two studs the first time I pulled a trans. I had to get it back together for the Mon. morning work run so I drilled out the broken studs and through bolted the flanges. Don't forget the Never-Seize thread lube on all the threads.
39 minutes ago, Patcon said:
Do they not make a copper exhaust nut or a copper coated nut that would work for our cars. Correct thread and pitch... Would eliminate some of the broken studs issues I believe...
 You should be able to source brass nuts from a local bolt and fastener company. I Googled metric brass nuts. Lots of sources there too. Stainless steel nuts might be an option too.
They don't look terrible.  The thing about rust is that it expands when it forms.  It's not really two parts rusted together it's rust filling the gap between two parts.  At least you only have one part rusting.  Those brass nuts will probably expand quite a bit with a torch on them, and they have good solid flats to fit a wrench on.  I used stacked extensions and a breaker bar from underneath on mine, with a good socket, not a cheap loose weak socket.  You get one good shot, prepare well.
It's a dice roll, still.
You might find also that it only moves when it's hot.  I've had that happen on several parts.  Heat it, turn it, heat it, turn it.  I've also had the stud come out with the nut attached.  I actually re-used it as a bolt, it was the only one I had at the time.
digging around I find nuts for sale at MSA 7$ each, while zcardepot has nuts and studs all 3 for 13$. Looking closely it looks like the 13$ uses much shorter nuts, that is if the pics are accurate. Need to source these if I go the nut splitter route.
Found a local nissan dealr for 4$ each on those nuts so went that route.
Edited by Dave WM
