sweatybetty Posted May 1, 2016 Author Share #13 Posted May 1, 2016 10 minutes ago, Zed Head said: you posted a picture of how it came out of the car in your own build thread. could be the body is not quite right. you could take a measurement. maybe someone will take the same to compare. duh! i never thought to look there. thank you Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494001 Share on other sites More sharing options...
motorman7 Posted May 1, 2016 Share #14 Posted May 1, 2016 Here is the mustache bar installed Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494012 Share on other sites More sharing options...
Diseazd Posted May 1, 2016 Share #15 Posted May 1, 2016 The position of your diff mount and mustache bar depends on whether your Z is a Series 1 or Series 2. The Series 1 (early cars) had a shorter driveshaft and a more angular position of the half shafts. To remedy this, you could flip the tranny mount 180 degrees and use a series 2 mustache bar (curved versus flat). This moved the diff back, therefore the half shaft problem resolved. You also had to add the later rear hangars (curved to accept moving the diff rearward) and the longer driveshaft. To figure out which is which, figure out what you're running. Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494014 Share on other sites More sharing options...
Zed Head Posted May 1, 2016 Share #16 Posted May 1, 2016 considering your early vin number issues maybe somebody just jammed the diff in with the wrong parts. mgith want to start over Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494015 Share on other sites More sharing options...
madkaw Posted May 1, 2016 Share #17 Posted May 1, 2016 I believe mine rides that close as far as moustache bar to downlinks. I too have an early 9/71 using a r180. Sent from my iPhone using Classic Zcar Club Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494019 Share on other sites More sharing options...
Diseazd Posted May 2, 2016 Share #18 Posted May 2, 2016 On April 30, 2016 at 3:52 PM, motorman7 said: Looks like that mount on front of differential needs to flip around, long portion in back. If your set up is a Series 2, you need to install the diff mount so it moves the diff rearward. Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494048 Share on other sites More sharing options...
sweatybetty Posted May 2, 2016 Author Share #19 Posted May 2, 2016 from what i can find my car mfg date is 1/72. i didnt get the parking brake cable today, so, everything is on stand-by. i would like to thank you all for the help, though Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494053 Share on other sites More sharing options...
gundee Posted May 2, 2016 Share #20 Posted May 2, 2016 This is an installation on a 2/72 build date. Yours will be the same is this. Very easy install. Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494056 Share on other sites More sharing options...
Diseazd Posted May 2, 2016 Share #21 Posted May 2, 2016 It looks like you have the Series 2 set up and Motorman7 has the Series 1. In that case, you would install the mount the reverse of his (whichever way it moves the diff rearward). Your mustache bar is installed correctly. Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494058 Share on other sites More sharing options...
Zed Head Posted May 2, 2016 Share #22 Posted May 2, 2016 (edited) there are four different mustache bars out there. they have part numbers painted on them. if yours isnt red yet you could check that number Edited May 2, 2016 by Zed Head Link to comment https://www.classiczcars.com/topic/55367-differential-wont-go-in/?page=2#findComment-494090 Share on other sites More sharing options...
