Ok. So I've had some time to work on the car this weekend.
I started fitting the fender and assorted front end parts
I ran into a problem with the fenders and cowl. the gaps weren't even and didn't run straight. So I added onto the edge of one side of the cowl and on the fenders I cut a slot in and made the panel flush with the cowl and welded it all back up
20180901_180501.jpg20180901_180505.jpg20180901_183413.jpg20180901_183416.jpg20180902_172718.jpg20180902_172734.jpg20180902_172735.jpg
A little smear of fiberglass and some blocking and it aught to be good
This is the most assembled the car has been in NINE years! :wow:
The hood needs some more work and I will have to slot it a little bit to bring it forward some more. I will also have to re-arch it. I plan on using Jeff's method @Home Built by Jeff
I was able to locate 4 cowl screws in my bolt boxes. What is the correct finish. Yellow zinc or clear?
Also, does anybody have one of these inspection door shims. I have one on the car. I really need another or I could probably bent the bracket...
11 hours ago, Home Built by Jeff said:
Nice work. If you noticed with all the work I put into my bonnet, I ended up giving up and just bought a repro one. I am ashamed of myself for caving in, but I gave it my best ?
Some times you just have to punt.
I think I can make this one work if I elongate the holes some in the hood. This is an aftermarket hood I bought 25 years ago after I t-boned a post. It's close to working now. I will probably tinker with it some today
14 hours ago, Patcon said:
On another note, when removing the car from the rotisserie I dropped it about six inches onto the jack stands and dented the frame rails. Two steps forward ; one back
Ow. Ow. Ow.  That couldn't have been a good moment (looks like something I would do).  How well did the rail respond to the slide hammer?  Did you have to use any heat to get the metal to shift?
I came up with this. I believe there are a couple of layers of metal in the frame rail there. So a jack stand, a section of pipe, some chain and some studs welds and you get this
Add a big hammer
It worked pretty well but I will still dress them up a little bit with a thin layer of fiberglass
Worked on getting panel gaps right on the front panels some today. I think I got the hood pretty close. It sits just forward of the head light buckets, but they are pretty close. I also re-arched the hood using Jeff's method. It works good but be careful. It is easy to over arch the hood!
The cowl panel was sitting a little high compared to the fenders. I had crimped it when adjusting it. So out came the body saw and I added a slit. Got it flush and welded it back. As a word of caution it ended up too low after it cooled. I should have held it up just a hair to make it better when it cooled. I dollied it some and got it back to where it needed to be. I did both sides this way.
Then I moved around to the drivers door. The car had clipped something before I got it on the door and creased it right through the wheel arch. So I patched it in with a tabco panel a number of years ago. Well when I got the door on the car the tabco panel doesn't arch the same way the door does. So out comes the cut off tool
I started filling this back in when I stopped for today
Also I hung the new air dam on the front. It's a Xenon urethane dam I have had for a while. I don't like the way it meets the front fenders. Has anyone else had this issue? How did you deal with it?
I pushed the air dam forward so the back edge lined up well with the wheel arch and with a die grinder removed enough of the urethane so the bumper recess lined up with body bumper recess.
I could also do that with the edge of the wheel arch where it's too wide. Good idea! Thanks Chris! :beer:
Where the air dam curves around the front at the turn signals, did you put the air dam on the inside or the outside of the sugar scoop? I have it on the inside currently...
Edited by Patcon
  • Who's Online   1 Member, 0 Anonymous, 1,251 Guests (See full list)
