I have a question. Is there a way to identify a factory Nissan windshield gasket? I have a used gasket thats still pretty pliable. I would clean it up and use it if I knew it was a Nissan part. Otherwise, I will buy a clean new one...
I can’t tell “how” with my poor English skill but I am sure we can tell the difference if we have both in hand. I see the difference on the surface of the rubber, it looks different and feels different in touch.
But some reproductions are useable without serious problems I think.
Kats
Kats
Thanks Kats
I assure you, your English is far superior to my Japanese!  😁
  • Haha 1
So I started on the emergency brake cable redesign. I've been procrastinating on this
So I pulled it back out of the car, which is a pain with the differential in place!
Cut off the factory end :blush:
Welded the pin
When I welded the back side of the pin, I burned through the cable.
So I had to redo it
I worked on the headlight buckets some more
A little heat and the caps will come off
Then I noticed that the buckets were different. The older ones with the caps and then I assume a newer style that the plastic adjuster thing is all one piece. I tried to get some of these out of the buckets but that wasn't going to happen with out destroying them!
43 minutes ago, Patcon said:
When I welded the back side of the pin, I burned through the cable.  So I had to redo it
When you did it a second time, did you weld both sides of the pin, or just the far side from the cable?
Also, did you consider silver brazing the cable into the pin? I think I would have tried that.
  • Thanks 1
Silver brazing might work. Especially if you dish both sides to lock it in. I only welded the back side on the second attempt. It seems to be pretty strong but it's going to see some significant force, so we'll see ...
  • 3 weeks later...
  • Who's Online   2 Members, 0 Anonymous, 1,321 Guests (See full list)
