30 minutes ago, SteveJ said:
I think it may be a change in business priorities. I met Steve Richardson over 25 years ago. I believed he was the manager of the parts department & Z enthusiast, and that was the hey day of buying Z car parts from them. I noticed the inventory of unique parts faded after he left. Without a champion in the parts department to support the older cars, it can be a tough sell to continue the effort.
Courtesy is probably like most dealerships in that they do not keep seldom ordered parts in their inventory but rely on a warehouse for those items. I think everything I've puchased in the last few years have been warehouse supplied and I use store pickup to avoid shipping charges.
Edited by jfa.series1
On 1/29/2024 at 11:26 PM, inline6 said:
Also, I have updated my 240z fastener information at this Google sheet.  The hatch hinge hardware is in the body section.  The other related hatch hardware is in the body exterior section.  I need to organize things a bit better in the sheet.
Now I may be missing something but it appears the sections of the document are collapsed, and I can't seem to be able to expand them...
A little more tinkering
So I used an old hotel key to help get the clips on
Thanks @Namerow
It also helps to lift the scupper from the underside in order to get the clips on
Here are the pin clips that come with the badges from Resurrected Classics
I applied a tiny bit of urethane sealant at each post too. Then I covered them with towels and added some weight overnight
So here's a question, I have the upper outer hatch seal. It has a bulb on it. But the lower side seals are squarish. Is this correct?
  • Like 3
Hmmm. I wonder if it is a permissions thing.  I will have a look to see if I can resolve.
Evidently, there are no permissions levels that are suitable to allow others to expand the sections.  So, I have opened them all up.
Edited by inline6
  • Thanks 1
So best I can tell. The AC evaporator connects like this.
There must be a piece of metal here that helps connect these two to the factory mounting point
Here are some pics of the stock evaporator
BTW this thing is fragile as egg shells!
How exactly does this little valve work and will it work with 134a? I was thinking I would run a rotary pump under the hood and use the "stock" AC evaporator.
I'm not interested in going vintage air at this point
Was a frustrating day in the shop today!
Can't work on the heater because I'm waiting on a valve. Can't install the fender because the weather strip I had for fender sealing panel is not thick enough. I also need to touch up the engine bay paint. Can't install the hatch because I am gluing the hatch boots in... on and on
So I piddled some
I did get the catch down stoppers in. They are available new from Nissan currently
I found the bolts for the hatch but two are the wrong finish. So I will need to redo them. I did glue the hinge boots in. I used a black latex caulk. I didn't want to use anything more tenacious in case I need to get them out
I pulled the dash out and was going to clean it up. Wow, is it rough!! I guess I will see about getting a new dash.
Where is the best place to source the reproduction dashes?
I had thought I would try repairing this one but I didn't realize it was totally broken through in a couple of places
The real pisser of the day was the windshield!!! :angry:
We had it most of the way in, up around the passenger top corner and up to the other top corner and I pushed on the lower passenger corner to seat it and broke it...
Zcar depot has them but the freight quote was like $400+
I will call my local auto glass company and see if they can get one. I plan on seeing if they will install it too. We'll see what they say. Many times they won't guarantee they won't break it. I obviously can break them on my own... All in all, a wizz poor day in the shop!!
  • Wow 1
  • Sad 6
