The 300ZX used a different pinion flange bolt pattern, bigger bolt circle.  The picture and specs below are from either Johnscars or brokenkitty, can't remember, but saved on Hybridz.  Looks like brokenkitty has left the ZCar world.  http://www.brokenkitty.com/zcar.htm
Easiest might be to swap a 280ZX or 280Z pinion flange over.
https://forums.hybridz.org/topic/125392-clarification-of-diff-pinion-flange-dimensions/
Edited by Zed Head
1 hour ago, Patcon said:
So here is a new problem!!
The CLSD R200 diff has an input flange that is much bigger than the rear of the driveshaft I was using in the "Brown Z"
So How do I solve this??
@grannyknot@Zed Head
You have to be careful here.  I think to resolve, you will need to swap the front flange on the differential to one from another R200 - to one that matches your driveshaft.  When you do, you have to torque the pinion nut to the right torque range.  If you do not, you will run the risk of quickly damaging the the "front pilot bearing", and suffering subsequent differential pinion/ring gear damage.
I recommend looking up the torque spec in the differential manual in the resource section and using the low end of the specification.  Why?  Because the bearings are not new... and I have found that once they have been "crushed" and run... the light end of the specification is enough torque to achieve the correct turning resistance on the pinion shaft.
The correct way would be to remove the differential.  Place on a bench.  Remove the carrier assembly.  Remove and replace the front flange.  Torque the pinion nut to the light end of the spec.  Measure the turning resistance in inch lbs.  Once you determine that is good, put the carrier back in, and reinstall the differential.
He'd have to have one made.  Everything after 1975 is a staked u-joint so that's a hurdle.
Might be able to find a flange with the DAT-110-300ZX pattern.  I think that they are actual flanges that he used to sell as part of his V8 conversion kits.  Not sure though if they are differential flanges or propeller shaft flanges.  I never thought about it much when the web site was active.  He quit selling Zcar parts now though.  Might be worth calling the guy.  You can tell by the web pages that he's more old school than new.  Pretty sure that brokenkitty and Johnscars are run by the same guy.
Phone: (214) 426-4101
Fax: (214) 426-3116
Email: Help@JohnsCars.com
Mailing
Address
800 Jaguar Lane
Dallas, TX 75226
In situations like that I have always just made up an adapter on the lathe, then have the thickness of the adapter cut out of the drive shaft and re-welded by a drive shaft shop.  You could also turn the flange 10 degrees and re drill.
I have real concerns over swapping the flanges for just this reason!
It is not that much work to take the carrier out, swap pinion flanges, torque and measure turning resistance on the pinion.  You just need the pinion nut ft-lb spec and the turning resistance in-lb spec on hand... and good torque wrenches.
I have the good torque wrenches and at another time I wouldn't have an issue doing this. But I'm racing the calendar and don't want to use that much time to sort this out.
2 hours ago, Patcon said:
I haven't decided if I'm going to try to correct the wavy area.
I wonder, perhaps, whether you could fabricate a metal stiffener (tubing? U-channel?) and glue it to the underside of the lip. You'd probably need to use countersunk sheet metal screws (or flush-fitting pop rivets?) to pull the urethane lip down onto the stiffener.  They might need to be permanent.  I don't think the glue bond would hold up over the long term without some mechanical assistance.
Edited by Namerow
  • Who's Online   2 Members, 0 Anonymous, 1,031 Guests (See full list)
