9 hours ago, Captain Obvious said:
I suspect you're having the same "gas seems to have gotten less dense over the years" kind of level adjustment issue that has affected several owners.
That was my concern and I figure the high percentage result is to just use gasoline
Carbs are easy AF. lots of people don't understand them anymore these days... adn toss on EFI
Have them properly rebuild and they will work fine everytime . Modern gas is not a problem, just don't use ethanol based fuel
Unpacked my ZTherapy carbs in 2017 and bolted them up directly. Didn't touch them then and haven't touched them since. I have run ethanol free gas ever since I had the carbs done and with the "new" carbs I had to do the entire fuel system front to back at the same time.
  • 3 weeks later...
14 hours ago, w3wilkes said:
I had never seen a clear lens on the engine room light. Mine is more like frosted on my 12/71 car and it was also frosted on my 73 car.
12 hours ago, Yarb said:
There’s a story behind that and I’m pretty sure that will be answered in good time.
I was restoring a bunch of inspection lights and all needed new lens. I contacted 240Zrubberparts to see if I could get a quantity discount. He asked if I wanted "crystal clear" lens and without thinking I said yes instead of specifying opaque. So... I have a bunch of lights that do not look like OE and I occasionally gift them to friends.
  • 1 month later...
So it's been two months but I made it back into the shop today.
Spent most of the day cleaning up and putting tools away.
I got a package from Sean a week or so ago
I unpacked it this evening
On another really disappointing note!
The brake system has fluid in it. And apparently it has a leak and was unattended for two months. :angry::angry::angry:
  • Sad 4
