I have. I don't see how you fit a scissor jack on the end of the the outer control.arm and 1) have enough room to spread the ends of the arms and 2) have enough room to get the axle stub on with the scissor jack in the way?
I have a question. How did you get the old bushings out? Did you punch them out with a hammer from the outside in? Its looks like the control arm is compressed, judging by the photo's. These control arms are strong in cetain directions and in others not.
Measure the distance between the control eyes. The distance should be 141mm. The stub axle is 135mm which gives you 3mm for the lip on each PU bush. If you spred the control arm with a jack, make sure its met these measurements.
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
