I think you are asking, how do you go about having a solid roof again with no sunroof at all and have the roof look like it was never cut up, yes?
If that is what you want to know, then you need to find a very good auto bodyshop, it is not the kind of job you want to give to an inexperienced shop. The hole in the roof needs to have sheet metal welded into place then ground smooth without warping the existing metal, then the imperfections will then be smoothed out with filler, lots of sanding and then paint.
As nix240z says, you could also have the whole skin of the roof replaced.
Find a good body shop first and see what they recommend.
good luck
https://www.classiczcars.com/topic/55491-closing-sunroof/#findComment-495370
  • Who's Online   1 Member, 0 Anonymous, 1,454 Guests (See full list)
