siteunseen Posted June 7, 2016 Share #1 Posted June 7, 2016 ...transmission fluid to come out of the speedo connection after topping off the transmission fluid? Thanks Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/ Share on other sites More sharing options...
Chickenman Posted June 7, 2016 Share #2 Posted June 7, 2016 No.. You can still buy the inner seal and outer O-ring from Nissan. Inner Seal = 32709-14600 Outer O-Ring = 32710-14600 1 Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496406 Share on other sites More sharing options...
Zed Head Posted June 7, 2016 Share #3 Posted June 7, 2016 Do you mean at the speedometer or at the transmission? there are a couple of o-rings n the ned of the cable sheath. I think that CO has posted on fixing that problem. People have reported fluid all the way up the speedometer. Not sure how that happens. Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496407 Share on other sites More sharing options...
psdenno Posted June 7, 2016 Share #4 Posted June 7, 2016 I replaced mine just a couple months ago. Common? No. Eventual? Yes. Dennis Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496408 Share on other sites More sharing options...
gnosez Posted June 7, 2016 Share #5 Posted June 7, 2016 I thought a bee stung me as I drove my 240 on a hot day. No bee, just gear oil that dripped on my ankle from the rag the PO had pushed up into the dash. The speedo cable turns, oil climbs up the cable, leaking O-rings and presto you have gear oil on your leg. Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496411 Share on other sites More sharing options...
siteunseen Posted June 7, 2016 Author Share #6 Posted June 7, 2016 11 hours ago, Chickenman said: No.. You can still buy the inner seal and outer O-ring from Nissan. Inner Seal = 32709-14600 Outer O-Ring = 32710-14600 Thank you Chickenman. I'll get those and replace. Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496442 Share on other sites More sharing options...
siteunseen Posted June 7, 2016 Author Share #7 Posted June 7, 2016 $5 for both. I at first thought it was the slave cylinder hose leaking. New crush washers were my next move then I'd have to bleed that again, PITA. I put a empty (of course) beer case box under there a couple of days ago and saw it was coming off the speedo cable. Thanks guys, you've saved me again. 8^) Link to comment https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496448 Share on other sites More sharing options...
