Do you mean at the speedometer or at the transmission?  there are a couple of o-rings n the ned of the cable sheath.  I think that CO has posted on fixing that problem.  People have reported fluid all the way up the speedometer.  Not sure how that happens.
https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496407
$5 for both. I at first thought it was the slave cylinder hose leaking. New crush washers were my next move then I'd have to bleed that again, PITA.
I put a empty (of course) beer case box under there a couple of days ago and saw it was coming off the speedo cable.
Thanks guys, you've saved me again. 8^)
https://www.classiczcars.com/topic/55582-is-it-common-for/#findComment-496448
