1 hour ago, zKars said:
I think your only hope is to add a pulley to the face of the ATI single groove pulley. Just adding a longer belt to get to the Compressor leaves too little belt contact length on ALL the pulleys.
Thanks.  You're probably right.  I was hoping someone had already don't it!  :-)
https://www.classiczcars.com/topic/55634-harmonic-damper/#findComment-496963
