siteunseen Posted September 17, 2023 Author Share #37 Posted September 17, 2023 Have you tried flipping that Z shaped pipe at the rear? My outlet right before the muffler is all the way up. Your's looks lower. Good luck, you'll get it I'm positive. Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657143 Share on other sites More sharing options...
siteunseen Posted September 17, 2023 Author Share #38 Posted September 17, 2023 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657144 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #39 Posted September 17, 2023 16 minutes ago, siteunseen said: Have you tried flipping that Z shaped pipe at the rear? My outlet right before the muffler is all the way up. Your's looks lower. Good luck, you'll get it I'm positive. You have the flanged kit. Mine is a slip fit, so the pipes can only go one direction. I have the pipe right against the trimmed diff and the muffler is too far outboard. As I rotate the pipe up, the top of the muffler is tight to the body, yet still is outboard. The long center pipe is touching the steel NVH damper bolted to the front diff crossmember. I will put the muffler back on and take pics this morning. Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657145 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #40 Posted September 17, 2023 5 minutes ago, siteunseen said: That's about the angle i tried. My outlet is at least an inch to the left compared to that pic. The left side of the muffler is against the body. If I move it to the center of the cutout, the pipe is below the diff and very low at the front diff crossmember. Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657146 Share on other sites More sharing options...
Freez74 Posted September 17, 2023 Share #41 Posted September 17, 2023 I installed one of those systems last year, and it fit poorly. Had to heat and bend the mid pipe to get it to clear the floor, and the rear pipe was too long. I cut a one inch section out of it in the straight part, and put it back together with a 2.5 inch band clamp. 1 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657147 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #42 Posted September 17, 2023 15 minutes ago, Freez74 said: I installed one of those systems last year, and it fit poorly. Had to heat and bend the mid pipe to get it to clear the floor, and the rear pipe was too long. I cut a one inch section out of it in the straight part, and put it back together with a 2.5 inch band clamp. That sounds exactly like mine. I figured cutting an inch out of the center of the Z pipe would help a lot. The long underbody pipe fits poorly, but I might be able to live with it. Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657148 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #43 Posted September 17, 2023 (edited) Here are some new pics. With the system installed as directed, the muffler is against the body and will not rotate to the left. I have no choice but to cut an inch out and reweld the pipe. Edited September 17, 2023 by Jeff G 78 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657150 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #44 Posted September 17, 2023 Here is the cut plan. 1 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657151 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #45 Posted September 17, 2023 Much better with 1" cut out. Still not a great fit, but it doesnt hit the body. 1-1/2" might have been better, but I'll live with it. This MSA chrome tip is a POS compared to the rolled version. I will find something better. 1 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657153 Share on other sites More sharing options...
Freez74 Posted September 17, 2023 Share #46 Posted September 17, 2023 Looks like you got it! I've been happy with mine since I got it to fit right. It is much louder than stock exhaust. 2 1 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657155 Share on other sites More sharing options...
Jeff G 78 Posted September 17, 2023 Share #47 Posted September 17, 2023 My welding skills are not great. I am okay where there was no gap, but I keep blowing holes while trying to fill the void. About half the circumference was tight together , but there was a 1/16" gap in parts. I'm getting there, but lots more grinding than I should need. 😆 1 1 Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657156 Share on other sites More sharing options...
siteunseen Posted September 17, 2023 Author Share #48 Posted September 17, 2023 I hope you won't have to add a resonator like I did. Luckily it's not too expensive if you get one in their stock. I think mine is 18" and they charged like $50 maybe? The resonator was $20 i remember that. Odd that my 2.4 did not have any odd noises, drones. They both sound great and are quite if you step lightly. Link to comment https://www.classiczcars.com/topic/55662-advice-lining-up-msa-exhaust-on-a-240/?page=4#findComment-657159 Share on other sites More sharing options...
