Does anyone know of a way to tell if a motor has been removed before?  I've checked the wire/speedo cable looms and they look untouched.  I'm thinking it's the originally installed motor and judging by the pedal rubber the 23,000 odometer reading is really only 123,000 miles.
I'm working on a sales ad.  I don't want any wrong info so I'm trying to figure this out.  Thanks for any tips.
https://www.classiczcars.com/topic/55673-original-motor/
Your title says original, but you're asking about if it's been removed.  You know that the early cars had the engine serial number stamped on the car's ID plate, right?  If they match, it's original.  Then you can say "numbers matching" engine.
https://www.classiczcars.com/topic/55673-original-motor/#findComment-497283
  • Who's Online   1 Member, 0 Anonymous, 1,366 Guests (See full list)
